Try an MOC3023--Not the same part but might work in your application.
PDF Data file can be found below; http://www.fairchildsemi.com/pf/MO/MOC3023-M.html
The chip can be configured as an static AC power switch.
Hope this helps.
Hope this helps.
Seraph said:Try an MOC3023--Not the same part but might work in your application.
Hope this helps.
Thank you very much!
Zc
