diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   foolish notion, 12GN7 model? (http://www.diyaudio.com/forums/tubes-valves/97045-foolish-notion-12gn7-model.html)
billy pilgrim 25th February 2007 10:33 PM
I have this foolish notion of building an input xformer coupled PP amp with a differential mu stage thingy as the voltage amp/ driver stage. I'm thinking of using a 12GN7 / 12HG7 as the plate load ....would any one have an LT spice model that could be shared? Or some other hi gm pentode? I'd be very greatful.
Or maybe someone could talk me out of it?
Bandersnatch 26th February 2007 01:27 AM
Hey-Hey!!!,
I have done similar. It was a cascode of two 12GN7, the lower one triode strapped and the upper running as a pentode. Output Z was ~80R at 9 mA. It was for a linestage plate load, and I ran a single L-C filter for the PS and ran the pentodes on 12.6VAC. The amplifier triode was the 12B4 and it's held the record for unmolested operation and exclusion from parts-donor status for new projects.
If you want to use a single, it should be fairly easy, if you want to run two, you will need to figure out some voltage refrences...:)
cheers,
Douglas
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
