correct # of poles source selector?
Hi all!
I continuesly see 2 pole source switches...but are not 4 poles needed? One needs also to switch grounds to avoid ground loops, correct?
With 2 poles one needs to connect all input grounds to the ground pad of the amp which can't be good ground loop wise.
Am I correct or is this complete banana?
Thanks! Have fun! Hannes
