diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Quick quick question ! (http://www.diyaudio.com/forums/pass-labs/95616-quick-quick-question.html)
guitvinny 3rd February 2007 05:50 PM
I want to build a alpeh 5 amp, just want to know for the power supply filtering it a good idea to use 120000uf 50v cap for filtering ?? or I am better with a bank of 10000uf 50v cap ??
Zen Mod 3rd February 2007 06:59 PM
Re: Quick quick question !
Quote:
if quality of caps in question is in same league-it's always better to use several smaller ones
GRollins 3rd February 2007 10:57 PM
I've seen arguments both ways. Basically, my feeling is that as long as the total capacitance is the same, then you'll be hard pressed to tell the difference.
I am currently experimenting with big caps feeding smaller ones at the devices--sorta having it both ways, if you follow what I'm saying. No final opinion, yet.
Grey
guitvinny 3rd February 2007 11:38 PM
I was also thinking to build a ``perfect capacitor`` by doing a decreasing series of cap.. like : 10,000uf --> 5,000uf --> 1,000uf --> 1uf --> .1uf to filter a whole range of freq.. and finally a RC to filter residue of inductance.. good or too much ?
Nelson Pass 4th February 2007 01:34 AM
Can't hurt....
:cool:
guitvinny 7th February 2007 02:05 PM
Hi again,
1rst : I can get 50000 uF 60V cap by vishay(sprague) or duracap(mallory) is there a significant difference between them ?
2nd: I was thinking to get 8 of theses but is it too much 100,000uf per rail (for aleph 5) ?
thank
Buhl 7th February 2007 04:20 PM
I would go for the Sprauge Caps, and I would put as many in as can fit in the cabinet - capacitance is on of the few things ou cannot have to much of...
Caps have been discussed over and over in here - size, make, configuration, C's L's and so on - try and give the search function a try......
Cheers !
Buhl
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
