Hi everyone
Iam currently fixing 2 denon pma250 se amplifiers,both have exactly same problem primaries open circuit............
These have been powered with external transformer and both work fine,good amps but transformers inferior.
I am after 2 toroidals 230 vac primary 2 x 30 vac +earth secondaries,120watt or 160 watt...
Thanks in advance ,i got these amps very cheap as faulty and dont want to spend a fortune a big e i transformer wont fit can not be higher than 60mm
