HipoFutura said:I'm looking for a transformer with 115V pri & 9V/1amp secondary.
TE62041-ND at Digikey
HipoFutura said:As well I need a 25 Ohm 15 - 50 watt metal clad resistor.
TDH35P25R0JE-ND also at Digikey
Re: Re: Need Help Sourcing Parts
or RHC-25-ND There are a bunch. Just search for resistor, then select wirewound, and select your criteria from the lists.
I just placed the order with Digikey. The tranny was a bit much, but I want to get this project wrapped up so I can enjoy the amp. The amp is pretty well done. I've built the case, assembled the components, etc. Just need to build this slow-start board. Thanks again guys! Don
- Need Help Sourcing Parts
