I am currently designing a full range enclosure for the Jordan JX92s. After discovering this forum I read that TL do not play well with subwoofers. I am planning on encorporating an 8" powered driver in this enclosure (seperate of course). The reason I am doing this is they type of music I like needs a little extra bottom and I hear that these do not have enough kick for rock.
Anyways. On the Jordan site there is a 3L plate basically for the 92s, doing some modelling I thought a 5l would work a little better...
Does anyone have experience with a sealed setup or really anything other than TL?
BTW if it matters, the Jordans will be powered by an Onix SP3 tube amp and the 8" will be Tang-Band W8-740Cs powered by a BASH amp.
Suggestions very much welcome, someone in Atlanta that could let me listen to some Jordans would be much appreciated!!
Jordan sealed volume
I think you're right about going to 5 L. I've got the MLTL, haven't done sealed, but I seem to remember 7 L for someone's sealed version.
There are some good posts on the Jordan and debates about enclosures at the FullRange Driver Forum. I just searched & found a debate between 3L and 5L, so you ought to get some good info there...
I'm just about to start building an MLTL design for the JX92S. I did the design using Martin King's 'Ported box' worksheet, and this predicts a lower -3dB point of 35Hz, so no sub-woofer should be necessary. Of course, it could be that the max SPL may not be enough for your application.
The overall enclosure size comes out at 800mm (H) x 164mm (W) x 266mm (D), so reasonably compact for a TL design.
