power demands
depends...
I have run both Acoustat (0ne plus 0nes) and inner sound (eros) panels with Antique Sound Labs Waves (8 watt mono blocks) and ouuld achieve decent listening levels on both. Bigger ams do sound better. A friend is running 0ne plus 0nes with an ARC tripath amp 300 per chanel and it sounds very good. Amps that don't like the load very much will work but not sound very impressive and lack dynamics. Regards Moray James.
Don't confuse average power dissipation with amplifier power capability. An amp that can handle and is playing 200W peaks may be only putting out milliwatts of average power. So the average dissipation will usually be much lower than the power capability (unless it is a class A amplifier).
hmm i dont think a cascade high voltage unit will consume 10 watt ,it may put out high voltage but absolute no current.
maybe it depends on the construction of the cascade but i know many desgigns where they tell you to let them plugged in.
And also discharging and charging the element all the time wont exactly expand life time. there is nothing wrong with having costand power on the mylar, at least i cant think of any reason why it should destroy either the mylar or the coating.
i think its more the thought of leaving equipment plugged in.
The HV supplies use very little power, my switching supplies use about as much light as a nightlight for the pair. It is possible to make a circuit to turn them off, but to me it's not worth the expense of building the circuit. My electricity is about $0.10/KW-Hr. I'd guess that the circuitry to turn the supplies on and off is about $50 for a pair if I am frugal and clever. At 7 watts, that is 71,428 hours to payoff. That is over 8 years; too long.
My DIY esl's play well using a pair of 20 watt amps, they are pushing it a bit with 10 watt amps. My 20 watt amps use tubes which aren't very efficient, but they are only on when I'm listening to music.
Everything I own plugs in, and my electric bill is still quite reasonable, so I don't sweat it too much. I do turn off light when leaving rooms, but I don't stay up at night thinking about it.
Sheldon
JinMTVT said:
you guys talked about shutting down the high voltage on the diaphragm when not in use
can you propose a simple effective way to make an auto on and off circuit to extend the life of the unit ?
i have seen such auto much times on subwoofer plate amps ..
Yes, you would start with a little power supply that is on all the time (oops, we defeated the purpose). then you'd have a connection to your audio input that would drive a high impedance stage (op-amp) set up as an active rectifier. The rectified audio is smoothed (integrated with a cap) and sent to a comparator. the output of the comparator changes state when the musical signal exceeds a threshold. Now the logic of the circuit: There should be a very long time constant RC circuit (this is the ghetto way) that either charges or discharges over a very long time. When the comparator changes state is restarts the RC decay process. If the RC circuit (think 555 timer here) decays past the timer threshold, then it turns the HV off. When the RC is reset, the HV supply turns back on. The real problem with this concept is that the many minute RC time constants can be flakey when they age (the board gets dirty etc).
the cheaper and easier way to go is to have the rectified and filtered audio signal go into a PIC microcontroller that does the checking and timing.
The big problem with turning off the panel is that many panels take a while to charge up. So you aren't listening to a properly functioning panel for a while.
The real issue here is the circuit to turn off the panel will use roughly as much power as the original power supply does. Defeating the purpose if you want to save electricity. Just pull the plug, it's cheaper and easier.
Turning off the power o the panel can slow the accumulation of dust and dirt in the panel. That can be a good thing, but it's easy enough to vacuum out the panel every year or so. I have never had a problem leaving my panels on all the time.
Sheldon
