Hello
I have run Morel domes with Morel 8,5" drivers before with good results before, but now i found a pair of Morel H10.1 drivers very cheap and have a question to the users here.
Have anyone tried to run a 2 way system with these bassdrivers and Morel tweeter?.
I have not found any frequenzy plots on the H10.1 drivers yet. but they seems to be able to go pretty high up (for a 10" that is)
T/S indicate that they will play down to about 50hz in bokses as small as 30-35L (i have a pair of 15" subs wich will take care of anything below that anyway)
I can go 3 way with 4,5" , 5,25" or 6.5" as midrange if i have to, but then with 4 ohm midrange drivers (have some lying around)
I have searched for diskussions about the H10.1 in 2 way systems. but not much usable info is to be found
Any advice?
Any advice?
