Need this IC SUPERMATCH PAIR LM394 to get my ML No23 up and running.
deafbykhorns Member Joined 2004 2006-11-01 12:44 am #1 2006-11-01 12:44 am #1 Need this IC SUPERMATCH PAIR LM394 to get my ML No23 up and running. ••• More options Share jackinnj Member Joined 2002 tech-diy.com 2006-11-01 1:08 am #2 2006-11-01 1:08 am #2 try Future Electronics -- this part was obsoleted by national semi a while ago -- you can also use the Analog Devices super-match pair. jack ••• More options Share deafbykhorns Member Joined 2004 2006-11-01 1:40 am #3 2006-11-01 1:40 am #3 MAT02 I found datasheet on MAT02, says direct replacement for the LM394. ••• More options Share jackinnj Member Joined 2002 tech-diy.com 2006-11-01 10:39 am #4 2006-11-01 10:39 am #4 MAT02 is obsolete -- Digikey has some SSM2210, and if you can take a minimum 50 pieces you can order directly from ADI. ••• More options Share jackinnj Member Joined 2002 tech-diy.com 2006-11-01 1:49 pm #5 2006-11-01 1:49 pm #5 The SSM2210 and SSM2220 appear available on ADI's webstore -- in PDIP and SOIC. Bob Pease has a good article in his archive on super-matching transistors. ••• More options Share A Apex Jr Member Joined 2002 apexjr.com Paid Member 2006-11-01 4:56 pm #6 2006-11-01 4:56 pm #6 I have 4 pieces of National LM 394 H in stock PM me if your interested, not sure what the difference is between the LM 394BH and the LM 394H Steve @ Apex Jr. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
