Behringer XO sequence
Its not only about resolution, its about practicality and rationality - or do you want to eq each two channels seperately, meaning to purchase three deq's for three way active setup?
The deq corrects the the roomresponse for the full spectrum, this then you divide via the dcx into two or three bands. The dcx also does the time alignment, if you run sub/sat configuration.
You want the master volume control last, so you can run in the digital domain with full gain, thus having the highest resolution there - keeping the bit count up.
