mur860 alternative
if you are using chip amps the effect is not so much, because they have great psrr...that kind of diodes help reduce noise in supply voltage, but this is still an open question, someone says it's better to use normal diodes...otherwise a good alternative will be adding a 100nF cap in parallel with each diode, simple, economic and works!
