diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   DIY Open baffle / Sealed woofer design (http://www.diyaudio.com/forums/multi-way/85301-diy-baffle-sealed-woofer-design.html)
preiter 24th August 2006 07:31 PM
I'm very intrigued by the Linkwitz Orion. Specifically, I like the idea of an open baffle for midrange/tweeter and a sealed box for woofers.
Anyone know of a DIY design in this configuration? Preferrably something that costs under $400 USD to build.
leadbelly 24th August 2006 08:11 PM
Re: DIY Open baffle / Sealed woofer design
Quote:
You left out the part (maybe the most important part) about the Orion being an active speaker. Is this also on your wish list?
What are you driving it with? For $400, you should consider just making a low efficiency version of the BassZilla if driving with plenty of amp power.
amt 24th August 2006 08:26 PM
Did you look at the PMT1, designed by SL as an inexpensive introduction to dipoles? The parts cost is under $400 and you could just add a cheap powered sub initially. A dipole sub/active xo could be added later. Easy to build and its pre-engineered. Check out Bruces write-up and his website.
http://www.linkwitzlab.com/proto.htm
amt
preiter 24th August 2006 11:42 PM
PMT1 looks like a good bet.
I already have a sealed sub, so I guess I should just be looking for dipole projects.
454Casull 25th August 2006 01:41 AM
The Orion subwoofers aren't in sealed boxes, and the tweeter is monopolar (almost all dome tweeters are).
john k... 25th August 2006 10:59 AM
The NaO Mini is such a design.
http://www.musicanddesign.com/NaOMini.html
It would cost a little more than you want to spend though. There is also a good discussion of combining a sealed box woofer with a dipole mid.
Nuuk 25th August 2006 11:42 AM
Antivir is reporting a virus when I click on the link in John's post above! :att'n:
john k... 25th August 2006 12:15 PM
Quote:
Which link? I'll check it. My scans don't show anything.
Nuuk 25th August 2006 12:24 PM
This one John.
I got a box up with some options including 'Deny Access' that was ticked so I clicked on OK. Then I got the page come up as normal so I don't know what Antivir was objecting too. :xeye:
PS Now Firefox is reporting
File not found
Firefox can't find the file at /NaOMini.html.
john k... 25th August 2006 01:02 PM
This one John.
File not found
I have updated my virus data base and scaned all the files and they are clean. I have no problems accessing the links with IE 6.0, IE 5.5, Firefox, of Netscape. I also tried a couple of different computers. No problems.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
