diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Neutrik XLR for Umbilical (http://www.diyaudio.com/forums/tubes-valves/84792-neutrik-xlr-umbilical.html)
dsavitsk 15th August 2006 08:59 PM
Welborne sells Neutrik XLR plugs for use on umbilicals under 100V/4A. Does anyone have an optinion as to whether they would be useable for higher voltage (~300V) but lower current (30mA)? If not, can someone suggest something similar that I should use?
Netlist 15th August 2006 09:10 PM
I can recommend the spec sheets at www.neutrik.com .
Personally, I'd look for Speakon types.
Some of these models are designed for high voltage.
IIRC the Powercon series.
/Hugo
pinkmouse 15th August 2006 09:50 PM
Yup, go for Powercon.
dsavitsk 16th August 2006 06:34 AM
I can only find these with 2 poles. I need something that can carry HT as well as a heater supply. Any thoughts? Do 3 or 4 pole versions exist ...
That brings up a second question. Is it a good idea to use a 3 pole with the heaters and the HT sharing a ground or a 4 pole where each has its own ground either connected at the PS, or with the heater floating? The amp is a preamp with a single tube with an output transformer.
arnoldc 16th August 2006 06:55 AM
Try Cliff Connectors - http://www.cliffcomponents.com/
garbage 16th August 2006 09:01 AM
speakon has up to 8 poles for
cable connectors and also chassis connectors.
pinkmouse 16th August 2006 10:40 AM
When I built my version of SY's Heretical pre, I ended up running all the grounds back to the PSU separately. It meant I needed an 8 pin connector, (+-12V , HT, and 5 grounds), but the resulting amp is dead quiet. After I'd done so, EC8010 suggested using computer style 9 pin connectors, apparently they have quite high voltage ratings.
kevinkr 16th August 2006 04:42 PM
Look up CPC connectors using google. These have the voltage ratings, pin count you need. There are vendors that sell them in sets with the pins included. (Can't remember the company unfortunately, I'll check and see if I can find information when I am at home, and post it here.)
Normally you have to purchase the contacts separately which if you only use them occasionally is a big, expensive nuisance. CPC are carried by Digikey, Mouser, TTi and others.
phn 16th August 2006 07:47 PM
The 9, 15, 21, 25, 37-pin computer connector is military spec'd, MIL-C-83513. Amphenol has lots of different mil spec'd connectors, some quite expensive. Now, I'm not one to take electricity lightly. But I can't see any reason why Neutrik XLRs, PERHAPS even microphone connectors, can't be used. 300V and low ampere should be no problem. It seems like Leben uses XLR between the PSU and preamp. Scroll down. I doubt the MIL-C-83513 has higher rating.
I shouldn't have to say this, but one of the most important things here is to use male and female connectors right. You don't want exposed pins with 300V. In that respect, Powercons and Speakons seem to be some of the safer alternatives.
pred 16th August 2006 08:35 PM
I looked at cpc connectors and they seem interesting, 600V and they are round so easy to make a hole in chasis.
While we are at connecting PSU and (pre)amps what is in your opinion better, just to house transformer in other box or to rectify filter and stabilize in one box and transfer to the other (maybe with some additional pasive filtering)?
Pred
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
