REcommend me some transformers for a PP EL84
Having read that a lot of people dislike hammond transformers I am open to suggestions to a decent PT and OT's for a PPEL84 in ultralinear mode.
Looking for 240primary and secondaries
240v at least 200mA
6.3V
6.3v / 5v
Would be great if anybody has any experience with both hammond and other transformers.
240v at least 200mA
6.3V
6.3v / 5v
Sounds like you're intending to use GZ34 rectifier (possibly in a hybrid bridge). GZ34 are expensive. A much cheaper alternative is a pair of 6CL3, which would need 6.3V @ 2.4A. Then, use a separate 6.3V (not toroidal) transformer for the heaters of your audio valves. That way, you won't get HT rectification noise crawling up your heaters and into the audio.
EC8010 said:Sounds like you're intending to use GZ34 rectifier (possibly in a hybrid bridge). GZ34 are expensive. A much cheaper alternative is a pair of 6CL3,
There's always fine examples of current production GZ34/5AR4 from JJ or Sovtek at fraction of price compared to NOS tubes. They work just as good. I just don't see how NOS tubes are actually any better, considering its high market value. I've been using these two brands WITHOUT a problem at all.
