diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   which remote volume control.....?????? (http://www.diyaudio.com/forums/parts/81257-remote-volume-control.html)
ssmith 11th June 2006 05:57 AM
I'm planning on building a DAC with integrated volume control... and am having difficulty making the final pot choice.
The condition is that the volume must have a remote facility, or else be able to be upgraded to have a remote later on... my search has narrowed down to two choices:
- Dact CT2 10 stereo pot (can have a remote unit from bentaudio.com / diycable.com added later)
- Welborne Labs (Welbornelabs.com) remote 1 stepped attenuator kit -- no knobs, just remote....
Opinions anyone? the Dact has good reviews, but some mixed too. Can't find any reviews for the Welborne unit....
thanks in advance!:smash:
theAnonymous1 11th June 2006 06:27 AM
I'm not sure if the pot in this kit is very good quality, but for the price you could always add your own.
I am having two of these sent to me so I can't comment on their quality just yet. I don't plan on using the included pot, I ordered a 6 ganged motorized ALPS pot to replace it with.
http://www.altronics.com.au/index.as...=item&id=K5026
Here is a good ALPS motor pot to replace the included one with.
http://cgi.ebay.com/ALPS-Potentiomet...QQcmdZViewItem
ssmith 11th June 2006 07:12 AM
If you're referring to the Welborne Labs remote kit, the volume control circuit is built into the pcb -- you don't need an external pot.
The dact option is basically a dact pot -- with the option of adding a motor and a pcb to give a remote function.
BTW thx for the bay link -- they have RK40 pots ("black beauty?") - thought they were discontinued....???
theAnonymous1 11th June 2006 05:18 PM
Sorry, I was referring to the questionable quality of the pot included with the Altrinics kit.
That seller on ebay can obviously get rare and hard to find ALPS stuff. The 6 ganged 10k pot I ordered is a custom job by ALPS and I can't seem to source it from anyone but him.
His prices are reasonable too, less than 40USD for the 6 ganged motor pot shipped to the US is one heck of a bargain.
jamesjung21 12th June 2006 03:42 AM
The pot included in this kit is one dirt-cheap quality carbon pot, but manufactured by the same manufacturer who makes those little green silvered-carbon pots (Alpha is the company's name).
If you buy this kit, I strongly suggest you to buy one of those Alps motor pots.
I got two of those black colored dual-gang Alps motorized pots, but I can't seem to get the pinout right... I followed the pinout as stated on the data sheet, but resistance seem to shift up and down :xeye:
Does anybody have an experience with this pot..?
Thanks,
James
ssmith 12th June 2006 07:53 AM
Quote:
the bottom of this page:
http://www.diyparadise.com/charlize.html
has a pin guide for alps pot (blue type), not sure if it'll help.
ssmith 12th June 2006 07:57 AM
my mistake -- indeed the pot on the Altrinics kits does not look so interesting.
The ebay seller is interesting... now I'm think of no remote and an RK40 'black beauty'.....! (which sadly does not appear to be available motorised).
SRMcGee 12th June 2006 09:01 AM
ssmith:
Have you considered the Dantimax (http://electronics.dantimax.dk/) or Twisted Pear (http://www.twistedpearaudio.com/) offerings?
I am in the process of building a preamp with a Dantimax remote control system but have not completed it yet. My experience to date has been with DACT CT2 attenuators, so that will be my point of comparison. Others seem pleased with the Dantimax kits.
Good luck with your hunt!
Regards,
Scott
jamesjung21 12th June 2006 11:49 AM
That's not the one... If my pots had only 6 pins, I would have figured out the pin out even with my eyes closed ;) Mine has 8 pins on the SAME row which makes it difficult to figure out which is for which channel, with 2 last pins being dummy support pins...
Altronics' remote controller kit is REALLY good and accurate, and having a cheap pot doesn't mean it's bad. I would definitely choose Altronics' version if I have to make a choice between Alps' and Altronics'.
James
theAnonymous1 12th June 2006 05:41 PM
Hi James,
Here is a link to a somewhat confusing spec sheet for your pot.
http://avpg.business.t-online.de/PDF/RK16812MG.PDF
It has a pinout diagram, although a not so good one. Here is what I understand from the drawing.
This is with pins facing up and shaft toward you from left to right....
Pin1 : Dummy/No Contact
Pin2 : Out 1
Pin3 : Ground 1
Pin4 : Ground 2
Pin5 : Out 2
Pin6 : In 2
Pin7 : In 1
Pin8 : Dummy/No Contact
I really hope this is correct; because the pot I just purchased is the same thing only with 6 gangs instead of 2. That means I have 3 rows of 8 pins to deal with instead of 1.
Hope this helps.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
