darkfenriz said:Looks like variation on Sziklai connection.
Nope...
darkfenriz said:
How does it perform?
Q1 is the emitter follower...Q2 is the diode which provides offset compensation....The current mirror provides bias for the diode....probably good idea to bypss it with 1uF to the +supply rail.
Ultima Thule said:.....an emitter follower........except that a single emitter follower introduce an offset?
Cheers Michael
Yup...
sawreyrw said:Mike,
I'm pretty sure this circuit will burn up in a few msec, if you actually build one. The current through Q7 will be over .3 amps, so it's power dissapation will be over .3*22=6.6 watts.
Rick
Where did you get 0.3Amps???
poobah said:Any significant output current will imbalance the emitter currents and therefore the Vbe.
It generally not the offset in emitter followers that upsets things... rather it is the fact the offset is nonlinear function of current.
Am I missing something here?
Try it...
Hi MIKEKS
I think that is an intelligent solution for a thermally compensated stage,with a similar-current mirror circuit.
The problem with this circuit is the difficulty to apply a NFB with all the one which achieves:a need of a selection of Q1 and Q2, that they must be equal in both channels of a stereo amplifier yield more tightening for the lack of the emitter resistors.
Another little problem is the signal noise ratio,held low for the high current flow. I don't have the datasheet of the ZTX 696 but with a standard VBE of 0.65 the current in Q1 and Q2 is 15 mA each approx:very high for a low noise input stage.
If you neglects this the circuit is a good way for a good music listening,with the possibility of drive a capacitive loads.
Well, I agree it is obvious why that is the case, but the curious thing is when you start thinking about what this implies for its application.
It got me thinking, the same thing happens with a "normal" EF if you start sinking current into it, but not if you source current from its output. So this one has a more symmetrical response.
If I were designing a circuit like this, a unity gain buffer with no DC shift, unless the load was very light, I'd just use another emitter follower at the output, and use the diff pair as a controller for the EF. At least that way I have the "unlimited" output drive in one direction. This one appears to be too simple for its own good.
mirlo said:It has the interesting property that the output impedance increases with increasing load current. Curious.
Interesting observation...I haven't been able to substantiate it though....
Seems to source and sink current more effectively than ordinary follower.........
Can you demonstrate your observation please?
Cheers
sawreyrw said:Mike,
Ops, the emitter current will be about 30 mA. The dissapition in Q7 will be around .6 watts. It won't burn up in msec, but it won't have a long life either.
Rick
True....Use two in parallel..
Ultima Thule said:..and this one not good enough?
Input impedance~ R1//R2...
Dodgy linearity?
- Offset Compensated Emitter-follower...
