diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Audio-Technica AT-PL120 (http://www.diyaudio.com/forums/analogue-source/80767-audio-technica-pl120.html)
gvr4ever 2nd June 2006 04:48 PM
Does anyone on this forum have one? Can you give a review? Amazon buyers give it great reviews, but audioreview.com doesn't have a single review on it.
I've been wanting to get in to vinal, but I was starting to get the impression that I would have to spend $500 and up to get anything worth bringing home.
I've never seen so many good reviews for a turntable in this price range.
http://www.amazon.com/gp/product/B00...lance&n=172282
The best play back device I have now is a SACD player, but I want to hear some good vinal. I've only heard it a few times on decent stereo's and I really want to get in to it. Is this turntable a good start, or should I save up for something better?
gvr4ever 3rd June 2006 04:24 PM
If someone doesn't have that exact model, could you comment on the brand name and turntables?
I think I had a pair of headphones made from them once. After about 10 years, the foam started to fall apart, but they were not high end either.
cogsncogs 3rd June 2006 06:02 PM
gvr4ever
Before you make the leap browse around here:
Needle Doctor
You'll find quite a few 'tables under $500, namely Thorens, Pro-Ject, Music Hall, Rega and others. The Audio Technica PL120 I would call a budget DJ 'table. I would save up/spend the extra few dollars to get a better turntable than have the morning after regrets. I'm sure we've all been there before! :D
Wayne
Edit: There have been a few problems with the Music Hall MMF-2.1, I don't know if they have been corrected or not. I don't usually do this but I would recommend the Pro-Ject, Rega or Thorens.
gvr4ever 3rd June 2006 09:29 PM
Thanks for the tip. I'm not in the biggest of hurry, so I'm not buying tomorrow.
I have a old sansui amp that needs a preamp board replaced or repaired, and to make things worse, I've misplaced the amp :(
Basicly at the moment, I have a home theater, but it's going in a home theater only room and I want a stereo for the main sitting room in the house, so it will have a SACD player hooked up to it, LD player, ect. I've yet to acually make my own set of speakers, so I will probably ebay some Infinity SMs or something till I build speakers. At the moment, my main set of speakers are Infinity SM115s for the HT and they still sound good. I've heard others that sound better, but they also cost over a grand too.
I'm going back to school for electrical engineering technology, so hopefully, I won't be guessing and figuring out speaker making by trial and error and more error then anything. I pretty much plan on spending time on the crossover design for awhile and not build anything till I'm happy with my design. Hopefully I can even buy some student versions of some of the nice software.
sreten 5th June 2006 08:22 AM
It seems a pretty decent turntable especially considering the DJ
turntable type competition. How it would fair against more Hi-Fi
oriented designs is arguable, basically if you like the look and
feel of a "pro" type turntable go for it.
The built in phono stage is a nice feature.
If you do first replace the cartridge immediately, secondly replacing
the slip mat with something more substantial will help a lot, try and
find a rubber pactise damper for a 12" snare drum, fairly cheap.
:)/sreten.
cogsncogs 6th June 2006 04:26 AM
Which ever 'table you decide to go with it will pay to upgrade the cartridge over the preinstalled one. It's the one thing that will, besides your speakers, greatly determine the final sound! :)
Good Luck and happy 'spinning' some vinyl!
Wayne
Not Enough Time 11th June 2006 06:00 PM
Hi I'm new to the forum
I have the AT-PL120 and have been very pleased with it, I'v had mine for a year now. It's rock steady with the quarz lock on. My only gripe is the azimuth adj. screw is on the bottom of the tone arm, I have mine mounted on concrete blocks with 1/2" foam core. Between the turntable and blocks. With two 18" subwoofers I can go to a little less than 1/2 vol. before I notice feedback.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
