diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Volts AC rating in power supply caps (http://www.diyaudio.com/forums/parts/80378-volts-ac-rating-power-supply-caps.html)
rick57 27th May 2006 05:56 PM
How many volts AC rating in the caps are sufficient for a power supply caps?
Iím building my first amp, Gordon Rankinís Bugle. www.wavelengthaudio.com/bugle.pdf
The Bugle schematic says PS caps: 2 * 100 uF, on a 330 VDC B+ line.
To convert to VAC, is it: 330 DC * square root of 2 = 467 AC??
And are there other factors apart from the formula, to adjust the needed VAC up or down?
Reason for asking:
While the formula yields 467, Iím wondering if I can use oil run caps rated 370 VAC, in lieu of the Rankin specced, but now n.a. Elna Cerafine caps, or better electolytics (Panasonic TSHA rated 450 VAC).
Eli Duttman 27th May 2006 06:38 PM
You got it backwards. The peak voltage of a sine wave = VRMS X 2^1/2. Divide 330 VDC by 2^1/2. Motor run caps. rated for 240 VAC or higher will do nicely.
In the 'lytic dept., use polarized Black Gates in place of the no longer available Cerafines.
knubie 27th May 2006 07:17 PM
Yeah, all is well as far as most capacitors are concerned but exceptions exists, motor runs, for example ASC motor run caps are 440AC but 800 DC, almost twice the DC rating......
knubie
rick57 28th May 2006 12:45 AM
(I had it the wrong way around, ok) but motor runs are an exception, mmm . .
Any views on polarized Black Gates v ASC motor run v better Panasonic (TSHA)?
jeff mai 28th May 2006 12:48 AM
Quote:
No, they follow the same rule.
rick57 28th May 2006 12:53 AM
I've read two others at AA Tube-DIY say similar to knubie . .?
Hereís one:
http://www.audioasylum.com/forums/tu...es/100947.html
Maybe the different construction ďallows themĒ to have different electrical characteristics?
jeff mai 28th May 2006 12:59 AM
No, you just linked to the rule I'm referring to. I didn't say knubie's calculation was wrong - I didn't check. It is wrong to consider motor run caps exceptional to any other AC rated cap.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
