diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   I completed my amp! (http://www.diyaudio.com/forums/tubes-valves/78986-completed-amp.html)
peppennino 5th May 2006 08:07 AM
I completed my amp!
I just completed my new 300B SET amplifier! After months passed searching for the components and building the cabinets, I finally warmed the solder! Infinite THANKS to my friend Derek Walton for his precious aid! and also to Joseph Esmilla for his fantastic scheme that we used as starting point. It sounds marvellous to my ears!!
Ciao a tutti
Vincenzo
http://homepage.mac.com/parisatnight...otoAlbum2.html
http://homepage.mac.com/parisatnight...s/DSC_9008.jpg
Geek 5th May 2006 08:31 AM
Nice work! :)
How on earth do you get the dovetails right? I have a dovetail bit for my router and always manage to scew it up :(
owen 5th May 2006 08:49 AM
Great work...
Those dovetails look hand cut to me - Kudos!
Owen
bibster 5th May 2006 08:55 AM
peppennino,
That looks wonderfull!!!!!
Dovetails... I don't even dare to think about it... alltough there seem to be kits with routerbits en guides that make the job easier...
Paul
Trout 5th May 2006 11:15 AM
WOW!!
That looks wonderful!!!
I love the wood knob!!
Trout
dstockwell 5th May 2006 11:26 AM
very nice...
Giaime 5th May 2006 11:41 AM
Ciao Vincenzo!!!
Can you tell me where you get the transformers, tubes, those big cromed capacitors, etc?
Thank you very much!
jaymanaa 5th May 2006 01:57 PM
Thanks for posting your amp and the link to your homepage. I am in the beginning stages of my first DIY tube job (just started drilling holes last night). Seeing real craftsmanship like your amp exhibits gives me much needed encouragement. Will any quality brand (Mars, GE, etc.) oil filled motor run cap do nicely, or are there certain types or brands to look for. I saw some on E-Pay that touted non-magnetic terminals. I just wandered if I need to be aware of any to stay away from. Thanks again and beautiful work, Jay
P.S. I don't think I'm ready to try those dove-tails just yet, but maybe on the next:smash:
ttan98 5th May 2006 04:13 PM
beautiful amp!!!!
I don't want to sound negative, the B+ @ 425VDC on the 300B is too much I believe that will reduce the the reliability of this EXPENSIVE tube....At this voltage you will only gain 1-2 watts extra...
dsavitsk 5th May 2006 05:00 PM
Quote:
Really? I have a set of Welborne 300B amps, and he has the B+ set at 550V, and he calls these the low volt version. I think 425V is fine for 300B's. In fact, I use cheap valve art tubes that have a lower than normal plate dissipation, and they have been fine for the better part of a year.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
