15000 uF
I am sold on the Panasonic TS-series of aluminum electrolytic caps. There are several sub-series, like TSNH (long-life and high ripple-current, low-ESR), TSU (85C general purpose), TSUP (mini-size 85C), TSHB (105C, hi-voltage, long life, low-ESR, high-ripple) and others. All are snap-mount, so if this is not what you need, you might want to check out the Panasonic screw-terminal caps.
My favorite is the TSHB for the high-voltage section of most AC-DC SMPSs. For the low-voltage sections (63V and lower, I like the TSHA series.
Just my $0.02 worth,
Steve
Steve
Not audio grade, but nice caps.
http://www.evoxrifa.com/electrolytic_cat/peh169.pdf
I use them in my bench supply
\Jens
\Jens
Paralleling 2 caps of hald the value. might actually end up being smaller, or might at least might be easier to fit into limited space. Two smaller caps are also a lot easier to find. Performance should be the same. The voltage of each would have to meet the voltage you mentioned though...
Apex Jr said:I should have these on my website by this weekend...
Steve @ Apex Jr....
Good Website Jr. Good products.
Shawn
rmihai said:Hi all,
I need one pair of the BEST 15000 uF capacitors, but first of all I need them to be as small as posible.
Any idea where I can find such a thing?
Thank you
Those are two incompatible requirements!
Any way the best caps i can think of, are the ELNA "for Audio" (LPO series) but i think the largest capacitance is 10.000uF (63V)
Check them out, they are great for their size.
The Panasonic are also a great choice
There are 2 others that I ordered too, and are in stock now
47,000 Uf 80V
68,000 Uf 100V
Steve @ Apex Jr....
hmmm...yummy, how much would you be selling them and do you have pictures?
thanks
Tony and Group...
They are now up on the website... www.apexjr.com
and priced. Listed on the New Arrival Page and the
Radial Cap Page...
Here's the link to a picture of the 22,000 Uf 100V
New stock made by Hitachi
www.apexjr.com/images/CAP22KMFD.JPG
Steve
Radial Cap Page...
Steve
Apex Jr said:Tony and Group...
Radial Cap Page...
Steve
wow! 105*C caps, do they come with clamps? and are you accepting payments via western union?, that is the only means avaialble to me.
- 15000 uF capacitors?
