Still reclaiming attic space, I have a couple of cases of SA-071 woofers and a case of the SA-TW1 tweeters.
SA-071 - $20 each, or make me an offer for multiples
Thiele Small parameters:
Fs (Hz) 45
Qms 2.6
Qes .65
Qts .52
VAS (ltrs) 22
Zn (ohm) 8
Re (ohm) 7.32
Le (mH) .5
Rms (Kg/s) 1.79
Mms (g) 16.48
Cms (mm/N) .76
Bl (N/A) 7.2
Sd (cm²) 143
2.83V SPL(dB) 87.3
Pe Cont (W) 50
Xmax (mm) 4
VC diam (mm) 19
SA-TW1 - $10 each, or make me an offer for multiples
Shipping at cost
Pictures to follow.
Fs (Hz) 45
Qms 2.6
Qes .65
Qts .52
VAS (ltrs) 22
Zn (ohm) 8
Re (ohm) 7.32
Le (mH) .5
Rms (Kg/s) 1.79
Mms (g) 16.48
Cms (mm/N) .76
Bl (N/A) 7.2
Sd (cm²) 143
2.83V SPL(dB) 87.3
Pe Cont (W) 50
Xmax (mm) 4
VC diam (mm) 19
Shipping at cost
Pictures to follow.
