which amp ? with Focal 33V2
Just wondering, how do you have those wired?
Those 33V2's are 'just' 2x150 watt nominal, so 4 of these, unless correctly wired, should not be a problem for the EP2500.
Nonetheless the quality of the EP2500 is questionable at least, you'd would probably be way beter of with a QSC amp (or even better, and my personal favorite, Lab-Gruppen) with less power than the Behringer amp.
