Length of feed back resisitor in NIGC
I'm building one of NICG, I'm thinking to use either Riken 0.5w or a cheap Royal Ohm 1/8 watt carbon film resistor.
I've heard that lenght of feed back resistor is very important, shorter is better. Royal carbon film resistor is only half size of the Riken. In this case, I'm not sure that which one is more important between Quality and Length ?
Which one I should use in this position ?
The other position will be Riken.
thanks
Thanks inguz,
I'm gonna post a picture of a small royal ohm, but you are quicker than me.
:D
