diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   LM4780 parallel transformer suitability (http://www.diyaudio.com/forums/chip-amps/73807-lm4780-parallel-transformer-suitability.html)
Dominick22 11th February 2006 12:29 AM
Part Number:
122-615
AVEL Y236503 160VA 22V+22V TOROIDAL TRANSFORMER
Is this a good transformer for paralleling two chips. I have been told to back down the voltage since I am trying to run Extremely Low Impedence speakers. They are ESL's.
But parts express offers 3 22v transformers with different VA ratings.
What VA should I get? Would one higher or lower than this be better.
I need a higher current.
Dominick
tiltedhalo 11th February 2006 01:36 AM
transformer suitabiltity
Trying to put into the simplist terms, V*A=W,so youve got a rectified voltage of +/- 27V about 1.5A to generate 90 to 110 Watts + or - so your supply will have to produce enough for at least 140 watts per parallel chip, for overhead. That 280watts 160VA wont make the grade on that one. least 330VA more like 500VA.
peranders 11th February 2006 07:34 AM
Re: LM4780 parallel transformer suitability
Quote:
Just wondering but how low is "extremely low"? 2 x LM4780 = 4 x LM3886 => over 40 A max! ....but with 25 V peak you'll need much less than 1 ohms. If most of the power is bass you don't need to design for max power at 20kHz.
Dominick22 11th February 2006 10:18 AM
I am trying to push the Martin Logan Ascent i ESL's which I am told can drop as low as .1 ohm at high frequencies. I will try to create some kind of choke that will prevent it from going below 1-2 ohms, but I just need a stable circuit for now. I already blew one chip in the standard parallel design with a 25V 330 VA rating. This was just one chip though and now I am trying it with two.
So what you are saing is that I should remain at 22V and get the highest VA rating I can?
Dominick
peranders 11th February 2006 10:56 AM
I suggest that you check with Martin Logan to get real facts. I have also Martin Logan SL3 and a single LM3886 has no problems with them.
Dominick22 14th February 2006 08:09 PM
I called Martin Logan today and they said that the minimal ohm load is 1.5 at 20k.
Considerably better than the .1 some people quoted.
So what should I look for?
22V at 400 VA????
Dominick
Dominick22 15th February 2006 12:19 PM
I am having a hellatious time finding a 22V Torroidal transformer with dual secondaries rated between 300-400VA.
Any help would be much appreciated.
BTW: I tried digikey, hammond, ebay, altronics, and parts express already.
I need some other website options.
Thanks,
Dominick
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
