hi,
spec is 5K:5K 25ma.
recently I collect some 80% supermalloy EI-66 lamination with 0.08mm thick from the remain stock of nippon steel crop. It contain two type of element ~78% nickel & 2% of cobalt.
I also order Furukawa "TEX-F" is coated with three insulation( ultra thin insulate layer) which prepare to call Daburu to OEM 5K:5K 25ma interstage transformers for tube amp.
This interstage will very good for use 6c45,417a,437a,3a/167m,5842, E180F ( triode connect) etc
5K:5K 25ma was working well of high gm tubes such as above were only a few examples. Tubes with internal plate resistances around 2,000 ohms or less will work well with this Interstage.
spec is 5K:5K 25ma.
size of the core was EI-66X40
Pls saw the spec of the new wire.
"TEX-F" is coated with three insulation layers which are of dedicated polyether sulfone (a super engineering plastic) and enhanced in high-frequency V-t performance.
Features
Temperature Index: F type (155°C)*1 under IEC 60172
Ultra-Thin Three fold Insulation (100µm)
Wide Size Choice of 0.2 to 1.0mm (diameter)
Fine High-Frequency V-t Performance
Due to the core only 38pcs.
It means only can produce 19 pair of this type IT.
I would like to try groups order for this IT.
Pls understand superalloy is very very expensive.
Hand over time will 1 month.
Furukawa wire was special order which was paralell 4 pcs of wire. in parallel form, Factory funish, not litz form to lower the loss of the HF & prevent skin effect.
Fubish look was hammer tone full enclose outlook.
Sample test in spec 26Hz~68Khz -1.5db.
Group price will USD 360 per pair.
19 pairs only because limited of the core only 38 pcs.
Postage include by EMS world wide.
Photos show the core.
thx
thomas
spec is 5K:5K 25ma.
spec is 5K:5K 25ma.
Features
thx
thomas
