Hi, I am new to forum so I don't know if this was discussed earlier.I tried to eliminate the volume pot but I encountered some problems as follows:
1.Gain is too high.
2.Sound is thin but detailed.
3.Dynamics overly increased.
I guess I should be adding some resistors somewhere.
Can anybody help me?
1.Gain is too high.
Search is your friend
Try this as a starting point
http://www.diyaudio.com/forums/showthread.php?s=&threadid=50870&highlight=sonic+impact
and this is a good site for diy beginners and SI mods
http://www.tnt-audio.com/clinica/t-amp_tweaks_e.html
There's also Tripath's website for info (check out Application Notes and Data Sheets)
http://www.tripath.com/support.htm
Re: Did I undersand right?
It's the input caps that are affecting the base. You need to replace them.....can't help on the gain question but I'm sure someone out there could advise.
I actually removed the 20K and replaced with 36K...not the other way around.
Pano, that's a good question actually...the wording and first diagram on your site show a 22K resistor but the schematic shows 36K?
Lee
hsu said:So I have to replace 36K resistors 4 and 5 with 20K ones and connect the pot wires together,is that all?
Lee
hsu said:You are right Lostcause, after checking with Tripath's data sheet,the original value is 20K actually...By the way why did you replace that resistor?Was that a modification,or did you change it into a dedicated amp?If so,I would like to hear your comments.
I modified a sonic T with the 'classic' input mod on Michael's site. I jumped in just before the feedback resistor (36K) with a matching value to set the gain. This bypassed the entire input section and filters. This is soon to be directly wired to a PS1's DAC chip (as per the thread on the digital forum) via a pot. Then put it all in a single box! That's as pure a signal path as you can get I think?...unless someone knows a better way of altering the volume?
Lee
- Class D
- How can I make a power amp from Sonic Impact?
