diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Gain adjust on an Adcom 545. (http://www.diyaudio.com/forums/solid-state/69499-gain-adjust-adcom-545-a.html)
K-amps 10th December 2005 11:47 PM
I just modded an old 545. I made it dual mono with extensive bypassing on the power caps. I also heavily "reduced" feedback and while I ensured equal voltage gain wrt the stock NFB, I feel there is a little more hiss than before at the output.
Using 111db Horns so need to tame the hiss.
I do not want to increase the FB back up because I LOVE the sound like this. It is much more detailed and punchy. The voicing is a tad thicker in the mids, which I like. But imaging and detils, much better.
Any ideas? Chris? Dennis?....Nelson?
Thanks,
K-amps
anatech 11th December 2005 12:39 AM
Hi Arif,
Less feedback = more gain. Now you need to try and reduce circuit induced noise. It won't be easy but may be possible. The circuit will have to be modified I feel.
You might want to try replacing the diff pair with FETs and clamping the drain voltage, cascode style. Just a suggestion. I haven't had a chance to try it myself yet.
-Chris
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
