Yes, I have searched... high and low. DIY pre's are rife with suggestions of the best caps and the best opamps but few are specific on the switch selections.
I would like a couple switch suggestions for source and attenuators. The catalogs show many but for a relative nuub, there are many, many possible selections. All with the possibility of being wrong and returns and credits and freight charges....
Can somebody suggest some good/better/best rotary switches for 3-4 sources and 12-20 stepped shorting. Part numbers are the key here.
Thanks!
Thanks!
good: Elma
(BV22568) 24 position special attenuator switch for mono Ladder L-Pads, shorting single pole per deck, two deck… $60.00 each
or
(BV22569) 24 position special attenuator switch for stereo Ladder L-Pad, shorting single pole per deck, five deck… $136.50 each
(04-2261) 6 position, useful as a stereo selector switch for those who wish to switch both hots and grounds or for use in balanced equipment as a stereo selector switching inverting and non inverting signals, non-shorting, two pole per deck, two deck… $56.00
better: Shallco
Complete dual mono ladder L-Pad attenuator kit with two 45 position switches and 176 Holco resistors, spec impedance… $273.00
or
Stereo series attenuator kit with one 45 position switch and 90 Holco resistors, specify impedance… $136.50
the best: TKD?
TKD Stepped Attenuator:...... 40 steps. 10K, 25K, 50K, 100K or 250K impedance.… $249.00/stereo attenuator
source: www.percyaudio.com
Regards,
Milan
or
better: Shallco
or
the best: TKD?
Regards,
Milan
