High voltage transistors for VAS stage
Okay, I've looked EVERYWHERE but have had no luck in finding the following:
I need to find a transistor model (BJT preferred, but MOSFET would do as well) with a breakdown voltage of at least 300V, power dissipation of 5w or more, current handling of at least .5 amps, and either NPN or PNP.
They will be used as both a common emitter and a cascode common base pair. I know most power transistors have these specs, but they are usually not good for common emitter or common base configuration. Currently, I'm using ZETEX FZT857 and FZT957 for my stage (3.5W per transistor), but they're getting over-powered in simulation for worst case.
Thank you! Your help is much appreciated!
are you designing an audio power amp?
Is 500mA necessary for a VAS stage?
Often a 50mA to 140mA device will do here.
A low current device will usually have a lower Cob which is often a prerequisite for this location.
Can an EF be used to help the loading on the VAS?
If you are really in trouble then I second the staggered cascode as a solution. But what are the drawbacks?
