Hi all,
I have just started my OPA541 based BPA-200 and i wanted to know if I could use 0.33 Ohm resistors insted of 0.1 Ohm resistors for the 2 parallel amps ? main reason is because i cant find 0.1 Ohm resistors near by me and second reason is because i have a load of 0.33 Ohm resistors!
Thanks,
Kinser
Thanks,
Kinser
Hi again,
Thanks for you relpys.. i think im going to do mateo88 said: Im gonna parallel two 0.33 Ohm resistors to make about 1.65 Ohms!
I do have 2 more Q's:
1. How do i parallel 2 amps? just add the resistors to the output of each amp and connect the same input the amps? (Like this http://mars.walagata.com/w/matttcattt/audio/Fig2.GIF exept in NI mode?)
2. can i use this http://sound.westhost.com/project14.htm circuit for the bridging part?
Thanks,
Kinser
Thanks,
Kinser
