I am looking into replacing the power supply to my denon dvd 2900 and some other components and I was wondering how the Modified Jung pcb's would work for this?
Does anyone hav information on how to set the voltage output on them? WHat is the max current that can be pull through them?
God bless....
Mark
God bless....
Mark
why not look at the homepage of the one who made the modified Jung regulator boards, Mark ?
http://www.aoselectronics.com/jungsrpcb.html
An LM317/337 handles 1.5 A, the D44H11/D45H11 does 10 A.
Take your pick !
The resistor value for setting the output voltage is above the circuit.
Mouser sells the D44H11/D45H11.
The LM3290Z sets the reference voltage at 6.9V.
Take your pick !
jacco vermeulen said:why not look at the homepage of the one who made the modified Jung regulator boards, Mark ?
Take your pick !
Jacco -- was that your letter in Elektor?
The older boards (from the original Jung/Didden article) are still available on AudioXpress's website:
http://www.audioxpress.com/bksprods/pcbs/circuitsbuild.htm
if you are cramped for space, you might consider the MJD44H11 and MJD45H11 -- these are a bit smaller, DPak -- handle 8 amps. In talking with ON-Semi I figured out the correct heat sink.
