Thank you for responding, i will change them.
Even without any mods i think the P/HP-850 is the most value in preamps today.
I use it for all my refrence when i build power amps,
I am now working on a High voltage 115-0-115 power amp based on a leech.Output devices are MJL4281A and MJL4302A.
I also have MJL21195 and MJL21196.
Which of the above transistors are recommended for high voltage use?
Thanks.
Thanks.
