diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   newbie Q on troubleshooting (http://www.diyaudio.com/forums/chip-amps/48709-newbie-troubleshooting.html)
esc 31st December 2004 03:02 AM
happy 2005 ...
need help in troubleshooting this entry amp as i'm just starting out
referring to this 22watt amp using TDA1554 http://www.aaroncake.net/circuits/amp20w.htm
have wired everything point-to-ponit, added a 50k pot and a headphone jack as input
power source was a 12v car battery
- is wiring all ground (signal or pwr) to a single point ok?
- followed the ESP troubleshooting page, and used 2x 100K safety resistors at both 12V+ and - ends for testing
- nothing was warm, not even the heatsink
- output voltage at the speaker ends were about 10mV
with or without an 8ohms load (this is ok right?)
- after removing the two safety resistors, and without load and input, the heatsink became warm but everything else was not
- power source voltage was about 15v
but output voltage at the speaker ends were also about 15v???
- 8ohms load heated very fast if placed in
- any give where i should start looking?
jaudio 31st December 2004 09:47 PM
check all connection bewteen power supply and chip. Make sure you get the right voltage at pins 5,13 and 14, check for cold solder points
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
