diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Whats the voltage rating on this wire? (http://www.diyaudio.com/forums/parts/42952-whats-voltage-rating-wire.html)
lgreen 20th October 2004 06:00 PM
I want to use some of this wire but I'm not sure of its voltage rating, here is the spec sheet:
http://www.jscwire.com/jsc_ss.taf?p=6091
It says UL CM and CMH but I can't figure out what those mean.
I hope to use this for 117 V AC and 80V DC.
AndrewT 20th October 2004 06:17 PM
Hi
Just guessing but your cable looks very similar to trailer lighting cable used for 12v. The inner insulation is thin and may not be robust enough to avoid damage. If it is trailer cable its voltage rating maybe 50vdc. Remember 117vac is 165v peak and add in say 6% regulation comes to 175v.
Try emailing the supplier.
regards
Andrew T.
lgreen 20th October 2004 07:08 PM
Called
OK, I called their customer service and they said 300V. Seems a little high.
Sch3mat1c 20th October 2004 09:08 PM
All sorts of wire is rated to astronomical values... frankly, I'd be scared if I saw 50V wire connected to a car battery. I mean, that's like no insulation on there. More of a mechanical than electrical hazard, it'll wear through easily.
I think most house wiring (10-14AWG) is rated around 600...
Tim
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
