diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   HAL-O Damping Instruments (http://www.diyaudio.com/forums/tubes-valves/42482-hal-damping-instruments.html)
Tazzy 13th October 2004 09:21 AM
Does someone have experiance with these dampening devices?
http://herbiesaudiolab.home.att.net/index.htm
Geek 13th October 2004 11:11 AM
There was quite a discussion on those a while back on Usenet. Google "vibration damper" on the group rec.audio.tubes and you should find something :)
IIRC, someone discovered a 50 cent automotive (high-temp red) O-ring worked about the same.
Sherman 13th October 2004 02:07 PM
I put two of the automotive o-rings on each of my amps tubes and to my surprise it made a positive difference. The tubes are less microphonic and the sound is "cleaner". For 50 cents each it is worth a try.
Geek 13th October 2004 02:58 PM
Gives mean idea..... the common 6GH8A is fantabulous in a mu-stage, but many brands are microphonic. LordCo Auto Parts, here I come! :D
alejo 13th October 2004 07:31 PM
Sherman, you use O-rings automotive teflon? please put a pic to see the look in valves.
thanks
alejo
GRD 13th October 2004 09:34 PM
Yes, I have used Herbie's tube dampers in a BAT CD player and in a Cornet phono stage. They work for me. I notice a smoother high end and better (more defined) bass. But there can be a loss of "air" or presence. I usually use the dampers on half the tubes as a compromise. I haven't compared inexpensive O-rings to the Herbie's.
Sherman 14th October 2004 01:14 AM
Quote:
thanks
alejo
I thought I had a pic on my drive but apparently not. :confused:
I'll take one and post it either later tonight or tomorrow.
Basically they are just little red o-rings that fit tightly over the tube. They don't have the little pads that the Hal-o dampers have, just a flexible ring.
fdegrove 14th October 2004 02:24 AM
Sure, lowered Q would have you believe that. If you care to check it thoroughly I think you'll notice that it wasn't meant to be there in the first place, at least not as you heard it at first prior to adding the dampers.
They come in blue, black, red...all kinds of colours really.
Basically they're just silicon-based plumber joints or automotive sealing rings etc.
They're more heat resistant than plain rubber rings and should have better damping properties as well.
For those of you really wanting to investigate how effective these device can be check out Pearl Hi-Fi. These devices damp and cool quite effectively at the same time.
Cheers,;)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
