Can hold easy 80 watts...but not continuous
As each circuit is in parallell with the speaker you may have load problems....when unstable amplifiers is used.....you can use it inside you speaker, or in your amplifier panel...but carefull to not exagerate in the quantity of indicators...as parallelling too much you will have some load problems to amplifiers.
I am using only two levels at home, despite have tested this one.
My SS amplifiers could hold 12 stages of meterings each channel without perceive problems listening. Was tested by minutes, as i decided to avoid too much ligths.... we are not in Christmas already.
I think all stable amplifiers can hold that.
regards,
Good luck
carlos
regards,
Good luck
carlos
