diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   MarkLevinson ML3 schematics ? (http://www.diyaudio.com/forums/solid-state/41297-marklevinson-ml3-schematics.html)
Hardi 21st September 2004 03:39 PM
Hello,
i have a defective ML-3 amplifier with many non-riginal parts inside. Someone used wrong resistors and semiconductors in both channels :( .
A successful repair seems to be impossible without a schematic diagram.
Any ideas how to get it ? Any help will be a appreciated.
Hardi
Tube_Dude 21st September 2004 04:03 PM
Re: MarkLevinson ML3 schematics ?
Quote:
Originally posted by Hardi
Hello,
Hi Hardi
Without a schematic, wow do you know that the resistors and the semiconductors are wrong?...:confused:
Konrad 21st September 2004 04:04 PM
http://home.kimo.com.tw/skychutw/index.html
Hardi 21st September 2004 05:06 PM
Hi Tube_Dude,
the guy that tried the repair before soldered some 2N3055 as NPN type transisrors in the output stage. And i know that this is not correct :D . Some resistors "visually" do not fit in their pcb position...and so on....a real disaster :(
@Conrad:
I canīt find the ML3 there. Only ML2 and newer 23.5 !?
Hardi
Tube_Dude 21st September 2004 08:53 PM
Hi Tube_Dude,
Hi Hardi
Now i see...;)
For some information about the ML-3 see:
http://marklev.com/
2N3055 for a 200 W amplifier!!!...:smash:
john curl 21st September 2004 11:23 PM
BAD REPAIR! Danger!
djk 22nd September 2004 10:02 AM
There are three different ML3 schematics, call the factory with the serial number.
They use MJ15011/12 outputs, 2N3584/2N6421 for predrivers.
Konrad 22nd September 2004 03:33 PM
Is there a "JC-4" :wiz: or symetric with/-out j-fets?
JP0400 6th August 2010 01:47 PM
Hi Hardi,
I have the same problem with one channel.
Have you obtain finally the schematics ?
Can you send them to me in the case of yes ?
Thanks a lot by advance
Best regards
Jean-Paul
tiefbassuebertr 20th February 2011 04:07 PM
Quote:
Originally Posted by john curl (http://www.diyaudio.com/forums/solid-state/41297-marklevinson-ml3-schematics-post478394.html#post478394)
BAD REPAIR! Danger!
Why ?? Maybe cause unwanted oscillation effects by certainly load conditions? Then various simulation sessions of this circuit are necessary before starting any aimless service.
Quote:
Originally Posted by Konrad (http://www.diyaudio.com/forums/solid-state/41297-marklevinson-ml3-schematics-post478141.html#post478141)
This URL is death in the meantime.
In which case was this URL mentioned? Are there online-schematic of ML-3?
I want to have all schematic versions.
here an auction from CH (Confoederatio Helvetica/Switzerland):
http://www.ricardo.ch/kaufen/audio-t...v/an628135428/
and pics from inside:
http://www.diyaudio.com/forums/swap-...condition.html
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
