Replacement for CDM 12.1
from my point of view there are more and better possibilities to use a cdmpro2... check the thread here on "digital" some weeks ago...
But anyway - how do you think the cdmpro will fit into the L1210 loading device?
Moderation Edit... hacked link removed by moderation
cheers
Michael
I recently picked up a cdpro cheap with the intention of swapping it into Philips cd723 with cdm12.1 .
However, the mechanisms cannot be interchanged easily due to the use of different protocols:-
http://www.diyaudio.com/forums/showthread.php?postid=470253#post470253
Cdm12.1 can be improved!
(Separate, and improved power supplies aswell as replacement microcontroller )
Lots of commercial, and diy examples out there!
http://www.hifichoice.co.uk/archive/perl/272_printreview.htm
http://www.hifiplus.com/t-rev2-6.html
http://www.avland.co.uk/marantz/cd14/
Kind regards,
Ashley.
Hello Sandor!
The replacement for the cdm 12.1 is called VAM 1202!
Regards Dominik
Differences are in the clamper force from the magnet of turntable (disc motor pulley) - see attachement. Same variation is between CDM12.1 and VAM1202
  • Philips CD713 CD723 CD753 VAM1201 Servive newsletter1999.pdf
