Hello,
i have a big LCD Panel, but no info on it.. don't know pinout, protocol or resolution..
The type number is Toshiba TLC-271A.
Dimensions are : 270x95mm (incl. frame)
I've searched the net and found only other requests for pinouts..
The panel has a 10-pin connector with very small contacts (circular holes, all in one line, low profile) and a 3-pin connector (probably power supply).
I don't even know the power connectors polarity or what voltages are expected
I'm hoping that there are other Toshiba LCD panels out there with the same interface.
There are six msm5839 on the back of the panel.
i can post pictures tomorrow if it helps..
Please help!
Thanks in advance,
Keyne
Please help!
Thanks in advance,
Keyne
