diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Chip Amp as tracking supply for preamp (http://www.diyaudio.com/forums/chip-amps/37545-chip-amp-tracking-supply-preamp.html)
drdagor 10th July 2004 03:59 AM
OK This may be totally off the wall, but here's the idea....
I've been looking for a low noise power supply for an ultra low noise pre-amp I'm building. (Transistor/IC... Please don't turn up your noses.) This is +/- 15 volt job.
Anyhow... I was looking at the spec for the National chip amps, and realized that they are just low noise op amps with high current output. The LM1876 (dual 2 amp devices in one package) is actually a good candidate for a dual tracking regulator.
The idea would be to build a traditional op amp regulator circuit for using 1/2 of the LM1876... (Apply a voltage reference to the non-inferting input, give it enough gain to get up to +15 volts, and let its own internal regulation and some bypass caps take care of the noise.) To generate the negative rail, you make the other half of the LM1876 a voltage follower, and drive the negative side with the mid point of the two rails. So the negative rail always tracks the positive rail. There is a circuit in Horowitz and Hill that pretty much describes this.
Does this sound worthwhile to any body else? Love to hear some comments.
analog_sa 10th July 2004 08:26 AM
This has already been discussed. In fact you will find your proposed circuit in the OPA549 datasheet. No idea if anyone actually tried it.
DaKi][er 10th July 2004 11:53 AM
http://headwize.com/projects/showfil...lmore3_prj.htm
somthing like the psu in this maybe?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
