simple 2->1 mixer
I like the idea of using unity-gain (or even gain controlled) buffers (amps) since the signal levels are below the power supply levels of 12V (in the application I'm considering).
Would you use a simple unity gain mixer stage after the buffers, in other words, two buffers to the non-inverting input of a single op amp? This could all be done on a 4-amp chip.
Ed
