Hi Nelson. I meant BOSOZ ( Bride Of Son Of Zen). What is your opinion and are there any changes you would make to BOZ if you were going use it to drive a 15K - 20K load? The dac I'm using uses caps on the analog outputs so I don't need the input cap in the original BOZ design but are there any other changes you would make? I think I could decrease the output cap size to about 2.5 uF - 5 uF.
Haah....! It's the first time. The master don't know something.for reasons unknown.
Go with the Balanced Line Stage Pre-amp
G,
My friend drives his 300B SE tube amp with the BLS (BSOZ) with excellent results. Though the preamps is balanced, running it single ended seems to be just as good as other SE pre-amp designs. I say this because the improvement was so much on my friend's system that, he's actually afraid to try back his old tube pre-amp.
For me.. I like to keep things balanced when going SS all the way.
BQ
G,
BQ
May be the master has his own preference. Well, BOZ is the best preamp I have built so far. Not as simple as it look. May be the simplicity makes it difficult to get right. I have seen other people's BOZ sound a lot worse than mine. But still I haven't found a preamp that I like more than a passive one. Only my mini-crescendo that cannot live without a preamp.
