diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Class D beginner, where to start? (http://www.diyaudio.com/forums/class-d/36528-class-beginner-start.html)
Bricolo 22nd June 2004 08:46 PM
Hi all,
I'd like to make a PA amp fir a friend, and class D amps look nice for that. Not very expensive, small size, small heatsinks.
But I've never worked with class D, where should I start?
Alex
Bricolo 23rd June 2004 09:58 AM
no one?
Pafi 23rd June 2004 11:27 AM
Hi!
You should try something simple first! Self-oscillating topology with complementary MOSFET output would be fine.
Bricolo 23rd June 2004 11:37 AM
I was more thinking about starting with the theory :D
How does it work, what topologies exist (the advantages and drawbacks of each), how to build one (which chips?)
Some kind of tutorial.
I've browsed some manufacturers websites, but didn't find much.
Linear: found ,othing
National: has 1 class D amp
Onsemi: nothing above 1W
TI: nothing above 20W
peranders 23rd June 2004 11:54 AM
Kolla Harris/Intersil, possible also IR.
Bricolo 23rd June 2004 12:13 PM
I must be blind, I found nothing on theyr websites (and don't know what kolla is) :(
Pafi 23rd June 2004 12:29 PM
There were posted many links recently.
Theory:
http://www.irf.com/product-info/audi...sdtutorial.pdf
And a "book":
Title: High Efficiency Audio Power Amplifiers; design and practical use
Author: Ronan van der Zee
ISBN: 90-36512875
(I loaded it down from intrnet, but don't know where.)
Devices:
philips (TDA8920 2*80W PWM amp IC)
www.tripath.com (PWM controllers+drivers up to ~2kW)
www.intersil.com (drivers)
www.irf.com (drivers+MOSFETs)
www.advancedpower.com (MOSFETs)
etc...
peranders 23rd June 2004 12:34 PM
Quote:
Kolla, sorry a swedish word.... = check
kolla = kollationera = collate :nod:
dmfraser 23rd June 2004 04:44 PM
Class D amps
If you're a beginner, first build an amp someone else designed. There are too many heart breaks in making the first amp you ever build one that you try to design. There are several good schematics available at www.schematicsforfree.mattsoft.net in the audio circuits section.
Bricolo 23rd June 2004 05:38 PM
the "audio schematics and manuals" li,k doesn't work :(
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
