Hello!
Suddenly my Quad 34 preamp looks like a Xmas tree. I think the cause might be that while messing a bit with the AC supply to my TD150 turntable (which is hooked on to the power outlet of the 34) a spike might have destroyed smth.
I have come so far as to conclude that there is no +/- 7,5V feed to the solid state switches.
The +/- 7,5V is created by a 15V zener diode between two resistors (180R and 300R) that are connected to +9,4 and -8,6V rails (that feed all opamps etc.)
However, the resistors take all the voltage drop except for some 0.94V. Have checked the zener - it isn't broke - and I have also replaced it with other 15V zeners I have in my box.
My imagination has run out, need help...
Schematic for the 34 here
Hmm...
Hello Jan!
As you see I have a (late) 34 which is way better than the old 44 I had.
Anyway, I have desoldered all 40xx (except the 4066 at the tape and radio/aux), but the Xmas tree still up.
I suspect the transistors at the buttons T5-T12. What do you think? Desolder the whole lot and check for broken ones?
Nice game you did yesterday btw...
Cheers
tom
Hello Jan!
Cheers
tom
Zombie
Thanks regarding the game
I once had a similar problem with my 34 after powering it up after some small modifications....
All LED's where on after power up, and I suspected a short or bad connection somewhere in the selector circuit (I didn't meassure the supply), but instead I just let my finger move around the top and bottom of the PCB to see if I could pinpoint the failure.... Not very scientifically I know, but it worked... Suddely the LED's where normal, and I haven't been able to recreate the failure since (this was 1 year ago, and my 34 is in use every day)...
Let me know if you find the "spot"
Hello!
I tried the New Age magic finger method, but no result.
I decided to measure the resistance between the the zener pins. I removed the zener and the two 100uF elcos. AFAIKS it should be an open circuit...I have a reading of 5-6 ohms.
This corresponds to the short circuit you suspected. Now it's just to find where...
Cheers
Cheers
- Quad 34 like Xmas tree
