What are the best amterials to stuff a vented subwoofer with and how much do you put in there?
Does stuffing mean you will have to change the volume for the design on WinISD?
Not related to the above but what should i tune the vent to if i'm going to use the sub for loud music and exlosive films?
Thanks for any help recieved
Vented subs are generally not stuffed they are lined with acoustic foam.
though you can stuff areas away well awway from the port, BAF
(bonded acetate fibre) also known as polyfill or pillow stuffing is
generally used.
Tuning the vent is a lot more subtle than simply choosing a frequency,
I don't know much about home theatre sub tuning.
sreten.
generally used.
sreten.
If you want the best for HT, I know that 16Hz. seems to be the magic number. At least 16-20Hz. for ultimate HT. I guess this would leave less room for being below tuning since there isn't a whole lot of musical information below 16Hz. ( yes I know there still is, but I'd bet that the LFE channel won't go that low with much intensity to really do damage).
Don't stuff a sub.
For a subwoofer stuffing is not only not required it actually may hurt response. I've tested a number of subs with and without stuffing/lining/damping and never found it to be of benefit and often response was compromised. Damping is a must with shorter frequencies but in subs where the frequencies are all significantly longer than the internal box dimensions (the wavelength at 100 Hz is about 13 feet, and it just gets longer as you go lower) damping does not help. Most manufacturers do so anyway because they're expected to, but not because it works.
Re: Don't stuff a sub.
You can't just pull out a number without considering the driver and enclosure you're tuning. At least I didn't think you could.Bose(o) said:If you want the best for HT, I know that 16Hz. seems to be the magic number. At least 16-20Hz. for ultimate HT. I guess this would leave less room for being below tuning since there isn't a whole lot of musical information below 16Hz. ( yes I know there still is, but I'd bet that the LFE channel won't go that low with much intensity to really do damage).
The driver may not be reproducing short frequencies, but isn't it possible that resonating enclosure panels might. I think there may be more to why manufacturers do it than because they're expected to.BillFitzmaurice said:Damping is a must with shorter frequencies but in subs where the frequencies are all significantly longer than the internal box dimensions (the wavelength at 100 Hz is about 13 feet, and it just gets longer as you go lower) damping does not help. Most manufacturers do so anyway because they're expected to, but not because it works.
Damping panel vibrations?
If a manufacturer, or anyone else for that matter, is using damping materials to counter cabinet vibrations then the speaker is flawed and damping is the least of your problems; a properly designed and constructed speaker, sub or full-range, should not have panels that vibrate.
There may be another reason why damping material is so widely used in subs, and that would be that the manufacturer automatically put it in under the assumption that it was required without actually testing the speaker to verify its efficacy. I tested my subs with and without, they work better without, so my subs don't have added damping materials.
Dannyball said:I have a huge roll of roofing felt for the inside walls and a roll of cotton wool.
Should i just line the inside walls with the felt and the wool?
For the tunning frequency of the vent WinISD has given me 34Hz but someone recomended 28Hz, how should i chose?
I was probably me that recommended a lower tuning than WinISD
gives, I like mildly overdamped bass alignments, they suit most
rooms better and they go lower, so IMO go with 28Hz.
Adding roofing felt to the walls is not necessary. As BF has stated
airspace damping is not strictly required in subs, but if you do it
apply the cotton wool to at least 3 non parallel walls, for each axis.
sreten.
Re: Damping panel vibrations?
I believe you forget that there are more reasons to adding damping materials than just attempting to reduce cabinet vibrations (I assume you mean unwanted vibrations as a consquence of using something like cardboard for cabinet material). Allow me to list a few very good reasons for experimenting with and using damping:
1. Damping high frequency reflections from inside the cabinet that would normaly escape the cabinet through the membrane as sound distortion. This is mostly relevant with frequencies > 100-150Hz.
2. Reduce or distribute standing waves throughout the cabinet.
3. Lower the cabinets Q value. This will make the cabinet look "bigger" to the driver, and it will behave equally. Afaik, many cabinet calculation programs supports the addition of damping material to the final calculations, giving a good impression on this effect. This is a good behaviour if you are, for instance, designing a closed cabinet that has to be as small as possible.
Of course the lack of damping material will indeed create a more "wild" and uncontrolled bass with alot of thunder and action that alot of untrained ears seem to have a certain liking for. I hope my post will make you give damping another serious try.
BillFitzmaurice said:If a manufacturer, or anyone else for that matter, is using damping materials to counter cabinet vibrations then the speaker is flawed and damping is the least of your problems; a properly designed and constructed speaker, sub or full-range, should not have panels that vibrate.
That it does which can be very beneficial. Some tests indicate as high as 40% virtual increase.
Agreed. I've gone to .5Q boxes after using higher value units and the overdamped boxes seem better to me.
As I mentioned my comments result from actual testing of a number of subs both with and without damping, and in every case undamped worked better. Parallel research by Koonce and Wright mirror my results, concluding that damping material is not only unnecessary but in many cases detrimental in speakers designed for usage exclusively at frequencies of 100 Hz and lower. The arguments as to why damping subs could be beneficial are logical, but it's results that count, not conjecture.
BillFitzmaurice said:As I mentioned my comments result from actual testing of a number of subs both with and without damping, and in every case undamped worked better. Parallel research by Koonce and Wright mirror my results, concluding that damping material is not only unnecessary but in many cases detrimental in speakers designed for usage exclusively at frequencies of 100 Hz and lower. The arguments as to why damping subs could be beneficial are logical, but it's results that count, not conjecture.
Whilst I agree it also depends on the aggressiveness of the filter
above 100Hz, a combination of an undamped interior and rather
high Q resonant modes of a port can muddy the midrange.
I agree performance below 100Hz does not need damping,
unless the box is specifically designed to have damping
included in determining its alignment.
sreten.
Re: Re: Damping panel vibrations?
Hope it has been crosschecked that stuffing can actually appear to increase Vas to the driver.
Have a sub where the carpenter goofed up; using the internal dimensions as external. The Vb which is supposed to be 27.7L is now about 23L. i.e. I've lost approx 5L. Under this circumstance the most convenient option was to add stuffing. This I did, but havent actually tested without. Just went by the book. A bit too late now to test. The driver & back panel has been bolted & sealed with synthetic glue.
Paradoxically I've read comments that stuffing takes up internal vol & hence need to be considered while calculating Vb. Now this is confusing.
Just hoping the theory is right i.e stuffing = smaller cabinets.
Re: Re: Re: Damping panel vibrations?
Yes it does but usually only used for sealed boxes, not reflex,
except you can stuff ~ 50% of a reflex away from the port.
The 20% effective increase you need is ~ on the limit
of what can be achieved. (For reflexes its ~10%)
sreten.
sreten.
Dannyball said:Not relevant to what i started this thread out to be about but; what can you add to the subwoofer, after you have made it, to make it sound even better?
Maybe a low frequency equalizer. I've got an AudioControl Richter Scale Series III that I've had fun with. The sub I recently built doesn't really need it, except for boost at 22.5 Hz, where there's usually not much if anything in the program material anyway.
- Stuffing anyone????????????
