diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Swap Meet (http://www.diyaudio.com/forums/swap-meet/)
-   -   FS: Vintage 1960s homebuilt Dual-Mono Mullard 5-20 amp (EL34/Acrosound TO-300 OPTs) (http://www.diyaudio.com/forums/swap-meet/324280-fs-vintage-1960s-homebuilt-dual-mono-mullard-5-20-amp-el34-acrosound-300-opts.html)
GordonW 24th June 2018 05:16 PM
10 Attachment(s)
This amp is pretty special.
http://www.diyaudio.com/forums/attac...4-jpg-jpeg-jpg
It's a classic Mullard 5-20 design, built in the 1960s. It's done pretty much by the book, except for a few upgrades which allow more precise calibration, and it has some exceptionally excellent parts choices.
http://www.diyaudio.com/forums/attac...5-jpg-jpeg-jpg
Here's the main features:
- Dual-mono construction (two of everything- transformers, chokes, etc)
- Everything built in mirror image, in both power supply chassis and output chassis
- Oil-filled power supply caps
- Output chassis is aluminum (hum and noise reduction compared to steel)
- Preamp/driver circuitry done on tag boards (very professional)
- All grounds on central bus (basically star grounded)
- Input gain pots
- AC balance pots on phase inverters
- DC balance pots on output tubes
- Adjustable bias resistor on output tubes per channel
- Heater hum pots
- Adjustable B+ voltage (tapped resistors in power supply)
- Teflon insulated wire
http://www.diyaudio.com/forums/attac...6-jpg-jpeg-jpg
It's also built with all the RIGHT parts. Here's what's in it:
- Stancor (Chicago Standard) PC-8412 400-0-400V power transformers
- RCA 5V4G/GZ32 rectifier tubes
- Thordarson 20C56 8H 200ma chokes
- Acrosound TO-300 Ultralinear output transformers
- Mullard old-stock EL34 output tubes
- RCA 12AX7A phase inverter tubes
- Amperex mesh-plate EF86 tubes
- Sprague Atom 100uf 100v cathode bias caps
- Pyramid oil-filled coupling caps throughout
http://www.diyaudio.com/forums/attac...8-jpg-jpeg-jpg
http://www.diyaudio.com/forums/attac...9-jpg-jpeg-jpg
http://www.diyaudio.com/forums/attac...1-jpg-jpeg-jpg
As you can see, this one was built to the nines, by a real craftsman. The layout is pretty much flawless from a technical standpoint- from quiet to noisy as you go from one end of the output chassis to the other, and the power supply is the same.
http://www.diyaudio.com/forums/attac...7-jpg-jpeg-jpg
This amp has been checked out, and parts that were out-of-spec were changed, only as needed. This required replacing all the electrolytic caps (they had excessive DCR), and two of the output tubes, but everything else is as-built,. and in-spec.
The amp sounds wonderful (very smooth, detailed sound with great imaging and very powerful, controlled bass that goes deep), and it's virtually noise-free (no hum at all- and you literally have to stand with your ear in the tweeter of most speakers, to hear ANY hiss or other noise at all from this amp- and then only if you're in a completely quiet room with no surrounding noise AT ALL).
This is what I would call an "heirloom quality" build- something that would be worth passing down to future generations. An example of "Can-do" spirit, and an exceptionally performing piece of audio equipment as well.
Selling for $800.00 plus shipping. US shipping only (no international shipping).
Thanks!
Regards,
Gordon.
GordonW 6th July 2018 03:52 PM
Sold.
Regards,
Gordon.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
