diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Bluetooth amp with led strip toggle switches. (http://www.diyaudio.com/forums/chip-amps/319161-bluetooth-amp-led-strip-toggle-switches.html)
AthenaGr 21st February 2018 09:27 PM
Hello everyone,
I am new here and also new with diying everything!
So here's a question/problem that no matter how much I Google it it seems I can't find an answer.
I made a frame with an led strip inside and I added a plexiglass on top with two speakers connected to a sanwu amp. I power them with a 12v dc and both work fine. So now I want to add 2 mini switches that powers them separately. For example I could power the leds for light but not the speakers and some other time power them both. Any suggestions on how to achieve that? I bought a couple switches but with the way I wire them I can't get it to work.
Thanks!
PRR 22nd February 2018 03:15 AM
1 Attachment(s)
"switch two loads"
AthenaGr 22nd February 2018 12:17 PM
1 Attachment(s)
I've tried that but I guess I'm not connecting the cables in correct order ?
Any suggestions?
PRR 23rd February 2018 03:19 AM
1 Attachment(s)
First wire-up so both LED and AMP are on all the time.
Then figure out where to break the connection so the LED and/or the AMP goes dead.
Put switches there.
AthenaGr 23rd February 2018 04:53 AM
I did what you showed me but I connected the black cables on the switches and it worked.
Thanks!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
