2A3/6A3 tube preamp
2 Attachment(s)
Hi
I want to DIY 2A3/6A3 preamp I want to know my schematic is work or not Attached the schematics of power amp and preamp Please give some suggestions to me Thank you ! |
1 Attachment(s)
Quote:
Work? Be a good music playback system? I think it does not have enough gain to work in most systems. The 417 stage does have good gain. The next 2A3 stage has very little gain to plate. The 2.5K:2.5K is unity gain. Then the 5K:16 plate transformer has voltage LOSS of 17:1. So two fancy tubes and two transformers for almost no overall gain. Why a 16 Ohm output on a preamp? Married to the power amp: the 805 grid needs a BIG driver. I'm not sure a single 2A3 will do. In any case the 2A3 will need about 45V peak at its grid to make full output. Since your preamp gain is 2.5 (maybe 3), this means you need a VERY large signal into your volume pot. Are you looking at transformers in hand and trying to make something? |
1 Attachment(s)
The power amp is working now with my 417A one tube preamp
I want to DIY new preamp (417A+2A3) I have 2.5K:600 replace the 2.5K:2.5K The preamp output transformer can replace by 5K:600 ? The inter-stage transformer of the power amp is 2.5K:600 My first schematic |
Using 2A3 for a preamp is like using a V8 engine in a golf cart...
Why are you trying to re-invent the wheel?
A google search for valve tube preamp circuit. Will give you thousands of ideas that can be used or modified within whatever budget you have. |
Quote:
LOL It's a little overkill, no? Seems like a giant waste of a 2A3... Almost as daft as using a KT88.
Using a directly-heated output triode as a "preamp" tube will most likely become a nightmare of microphonics. Only try this if you shock-mount and/or enclose the tube to keep ambient sound away.
- John |
Quote:
Honestly if the pursuit for the ultimate in sound quality and enjoyment I believe nothing should be taken off the table. If someone were to build a 300B preamp (or 2A3 or KT88) and demonstrate that tubes of all kinds should be considered, I'm all for it. Oh, and I should also say that sometimes I think we all should try something just for fun and to see what happens. |
Oh of course. If the reason is "because I can" I'm all for it. I've built a 16 6P1P stereo amplifier :P
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by
vB Optimise (Pro) -
Copyright ©1999-2018 diyAudio
