diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Suggestions for amplifier ratings (http://www.diyaudio.com/forums/solid-state/317863-suggestions-amplifier-ratings.html)
SamAnytime 24th January 2018 01:22 PM
If someone is looking to manufacture a modest series of audio amplifiers, say 3 to 5 models, tops, which ratings should these models have?
Obviously, it is not feasible to have a whole range of models, ranging from 50W to 5000W in 50W increments, so I'm looking for some input. Which wattages sell best?
Let's say I decide on three models: 100W, 200W and 500W per channel. Are these okay, or will I find out later that no one wants the 100W, whereas 150W would have been a better choice?
globalplayer 24th January 2018 01:37 PM
85, 175, 350 on 8 ohms.
Kay Pirinha 24th January 2018 01:37 PM
I'm not aware of any rule of thumb, but 1-2-5 steps make sense to me.
Best regards!
billshurv 24th January 2018 02:19 PM
As you need 10dB increase to be twice as loud, 10W, 100W and 1000W seems to cover the bases. Or in other words, if 10W isn't enough 50W will also not be enough!
mchambin 24th January 2018 02:58 PM
Quote:
Originally Posted by billshurv (http://www.diyaudio.com/forums/solid-state/317863-suggestions-amplifier-ratings-post5318846.html#post5318846)
You mean 10dB to be ten times as loud.
This makes sense from a technical point of view. I approve the dB approch.
Not sure it is ok from a commercial or emotional behavior.
What about 9dB steps ( x 8) : 10W 80W 640W
SamAnytime 24th January 2018 03:03 PM
Cool. Thanks all. Now what about headroom/ onset of clipping above rated power? E.g. for a 100W amp, should it be clean up to 100W sine wave, then slowly start distorting/ limiting as the amp goes into overdrive? Under worst case overdrive, the amp is essentially putting out a square-ish wave, which, even at the same peak voltage as the clean sine wave would be about twice the rated power. If you allow that the peak voltage at full overdrive is 120% of the peak voltage of the rated power sine wave, then at full overdrive the amp is putting out 3 times the rated power.
Have I got the figures right (approx) or have I totally lost it?
billshurv 24th January 2018 03:24 PM
Quote:
Originally Posted by mchambin (http://www.diyaudio.com/forums/solid-state/317863-suggestions-amplifier-ratings-post5318866.html#post5318866)
Nope, I mean what I said. To get to a perceived doubling of volume you need a 10dB increase in power. The ear is non-linear.
scottjoplin 24th January 2018 03:49 PM
If you are "looking to manufacture a modest series of audio amplifiers" I think you need to decide how much you want to confuse the purchaser, ie. RMS, peak or wattnot
SamAnytime 24th January 2018 03:55 PM
RMS, for now. We can think up the marketing shenanigans later, if at all. RMS watts into 8 ohms.
scottjoplin 24th January 2018 04:07 PM
Quote:
Originally Posted by SamAnytime (http://www.diyaudio.com/forums/solid-state/317863-suggestions-amplifier-ratings-post5318873.html#post5318873)
Quote:
Originally Posted by SamAnytime (http://www.diyaudio.com/forums/solid-state/317863-suggestions-amplifier-ratings-post5318906.html#post5318906)
In that case 100Wrms is all the victim needs to know ;)
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 17.65%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
